midnight rider
0riginal owner 1987 GN
- Jan 28, 2003
my car is running like crap and we cant figure out the problem. its blowing black smoke that stains asphalt and when i try to accelerate its spits and sputters (like the intercooler hose blew off) it is an intermittant problem and a real bugger to track down.
Heres what was done with the car before this started.
My k and n filter fell off on the highway after hitting a nasty pothole(montreal) and I drove the car for a few hundred miles with just a pipe and no filter. my bad. black smoke started coming out of the exhaust.
I got a complete tune up, fluids, plugs, wires, replaced broken Timing Chain,fixed oil leak at rear Main Seal. installed hi vol oil pump, and yes I replaced the k and n.
When I drove / idled the car, the exhaust was still black and now the car started sputtering on accelration. After a few days of this crap it turned out my intercooler hose clamp was broken and I thought id found the problem as the hose blew completely off while driving on the highway. It blew off 3 times before I could get to a store to buy a new clamp. i finally put on a new clamp and thought id fixed the sputtering problem and now the car would not start.
I had to have my car towed and my mechanic did the following. since he has the same car, it was easy for him to:
changed Mass Air
O2 Sensor
Cam Sensor (2)
Coil
MAP
changed Spark Plugs which were black
Checked all Fuses
no sensor reading comes out on the computer.
car can run great for 15 minutes at a time or 2 minutes without sputtering. there is no way to predict when its going to launch like a rocket or sputter. It wont stall, but there is no acceleration when it happens. it can happen during hard or soft accelration. When it works fine, the car is its usual speeding bullet.
any suggestions on where to look would be greatly appreciated.
the computer and chip are going to be switched over the weekend.
changed Mass Air
O2 Sensor
Cam Sensor (2)
Coil
MAP
Checked all Fuses
