First time post, I might need some help with setup. Heres my stage 11 combination. Pt 88 turbo stage 11heads 4 barrel intake converted for FI,160lbs. inj., Comp cams solid roller lifter,258-254 dur. 614- 614 lift, pt front mount IC fast fuel management sys. 400 trans with brake 390 gears 28/11 goodyears Car with driver 3450 lbs. Best time so far is 9.74 140.18. I am sure this car should be faster than this. what is my mistake? Is it in the setup? Need help please.
