Ok, well once I start sanding should I just aim to remove the peeling clear and then use epoxy primer over it?that car has been sprayed a couple times which is not abnormal. Fisheye eliminator is a bandaid, and some paint mfg highly discourage it.
there are a few spots on the car that are down to metal, would it be fine to sand off the clear and then go over both the metal and sanded clear with the primer or would that be an issue?
When do I use a sealer, and is it something I should consider?
