My latest MASSIVE parts list for sale, take a look..
BLACK MAGIC RACING
formerly turbo_canuck
I sold a ton of stuff in BG, but didn't realize i still had a ton more!! prices do not include shipping, shipped from canada, or maybe from my us addy if i happen to be going up that way...
86/87 parts:
-cruise control cable (2) - $25 each
-cruise control module (2) - $55 each
-stock throttle cable bracket - $35
-2 pairs stock 8445 heads - $100 per pair (1G)
- pair street ported heads - $350 (G)
-passenger side ic bracket - $ 30
-passenger side ic bracket cut for stretch intercooler - $20
-stock front sway bar - $40
-stock water pump - $25
-stock turbo crank (2) - $150 each
-GN driver’s side tai light assembly, chipped corner, driver condition. - $60
-Drivers side tail light assy, chrome painted black -$ 45
-passenger side tail light assembly, no bezel - $40
-Driver side door hinges, need one bushing, good shape -$45 pair
-complete EGR kit -$50
-blower motor - $40
-oil pressure switch, like new - $20
-tinted rear defrost window - $75
-set of stock rods and pistons - $60
-stock 2 bar map sensor (3) - $25 each
-rebuilt stock alternator - $175
- pair of stock axles - $50 per pair
-set of hard vacuum lines -$40
-stock flywheel inspection cover - $25
- 2 stock 20 bolt oil pan - $65 each (1G)
-stock GM knock sensor, used - $30
-BRF trans core - $275
-pair of GN t-tops, locking - $150
-pair of t-tops, from 85 cutlass, pull down handles, non locking - $100
1 spare pull down non locking t-top -$ 60
-complete pass. Side kick panel assembly - $30
-pair of decent grey arm rests, no cracks or splits - $35 pr.
-sequential tail lights kit, really cool - $60
-pair of t-top bags, GM - $60 pair
-t-type/turbo t hood ornament - $40
-2 oil return brass fittings - $15 each
-2 brass oil blocks - $15
-2 intake water rail fittings - $8 each
-2 small water bypass fittings - $5 each
-2 hi-speed fan temp switches - $8 each
-2 temp guages - $8 each
-GM fuel pump relay -$20
-3 power steering pumps -$35 each
-2 ps reservoirs -$30 each
-2 pairs stock valve covers -$35 each
-stock intake manifold -$200
-stock intake with ports opened up a little -$200 (G)
-2 stock oil pans (1G) - $ 60 each
-stock throttle body -$40
-stock fuel rail -$50
-stock vac. Block -$15
PERFORMANCE PARTS:
-4”long, 3” diameter hose, blue (2) - $15 each
-3”long hoses, 2.5”, one blue, one red -$ 5 each
-3”long hoses, 3” dia., black - $5 each
-4” long, 3” diameter hose, black - $15 each
-6” long reducer hose, 2.5” to 3”, black - $20
-Wiseco forged 4.1 pistons, stock bore, clearanced for stroker - $200
-FAST jumper harness/junction box - $200
-pair of stage 2 valve covers - $60
-hooker headers, good shape - $350
-hooker 2.5” test pipe - $20
-manley chromemoly stock replacement pushrods - $60 (G)
-federal mogul chromemoly pushrods, 8.2” for roller cams -$60
- 4 new denso 02 sensors, - $23 each
- v-plus volt booster -$50
- 1 airbag, with hose + valve - $35 (G)
-auto meter fuel level guage, pro comp ultra lite silver, new in box - $30 (G)
- auto meter pro comp ultra lite silver volt meter, new in box - $30 (G)
- auto meter pro comp ultra lite 3 3/8 speedometer, new in box w/sender-$120 (G)
-hollowed out cat - $25
-62 mm ported stock plenum - $40 (M)
- underdrive pulley kit -$65
-2 3” dump pipes -$35 each (1M)
84/85 PARTS:
-engine accessory bracket - $25
-braided down pipe - $20
-4 '84 t-type wheels - $ 150
- '83 regal header panel w/ grill - $175
- Pair of good cond. chrome headlight bezels for 81-84 - $80
V-8 BUICK PARTS:
- autometer mech. oil press. guage - $25
-New frame pads for 455 swap into regal, 64-67 skylark- $70
-0-15lb fuel pressure guage (autometer sport comp mechanical)- $ 25
-30-0 hg vaccuum guage (autometer sport comp mechanical)- $25
-stock 350 exhaust manifolds- $80
-350 Alternator/ac pump bracket- $35
-350 4 barrel intake - $75
-PRACTICALLY NEW B.O.P. TH 350 built to handle 600hp- $500
-B+M torquemaster 10" converter, 3200-3500 stall- $175 low miles!
-TA 310 hydraulic flat tappet cam + lifters, 200 miles - $175
-TA competition 350 headers- $290
-1972 350 4 barrel quadra-jet, fresh rebuild -$250
-350/455 non- AC alternator bracket- $70
-pertronix-equipped 350 distributor- $ 125
-Fully ported + polished 350 heads- $700
-TA 350 aluminum stage 1 intake- $300
I'm interested in the weisco pistons and the hollowed out cat. Also in the digital tailights .
JimG, HUMBLE-U2, pm's replied.
49-blues, i'll make you a sweet deal on all 3 items.. pm me
jasjamz, 3 pieces, it's the kit poston's sells, one crank pulley, crank fan mount, and alternator pulley. pm me your email and i'll send u some pics.
Turbo1, sorry, no more stock intercoolers, they all sold in BG for some reason.. ;)
87GNATIONAL, pics on the way.
braided down pipe, give me a call so i can make someway to get you the money, or call me at 323-385-3098, kevin thanks!
Freddy,
I PM'd you back with the green light, did you not recieve?
thanks
Jim
Parts
Interested in :
Hard vac. lines
Ps. Pump
Ps. Resevoir
CC. Cable
CC. Module
Throttle cable bracket
Small water bypass fittings ?
Intake water rail fittings ?
Thanks Denny
