hell continues.
I got the right rear end put in with the stock 3.42's. I put in my 50 pound injectors, extender, translator, intake tube. My BLM's are about 110 at idle with the BLM parameter set to 1. When the rpms are up, it goes to about 135. My fuel pressure is about 38 static. This is another issue I have to figure out.
I set my cam sensor. New plugs, new fuel filter. I really cant hear any leaks before the turbo and see no cracks.
I did the TV cable adjustment procedure as described on gnttype. When I adjust per that procedure, my tranny wont shift until I hit 4000 rpm. It also leaves it at about 6 lines on the cable. I have to back it off to about 4 1/2 lines to get it to shift at a reasonable rpm. Is this a sign that something is worn out in the tranny?
Problem is, I still have pretty bad mileage. I have the chip set to lean cruise, and the scanmaster confirms its working. The wheels spin fine when the car is jacked up. The tire pressure is ok, as well as the alignment.
I noticed my turbo spoolup is terrible, (wasnt always like this) but once it spools, it has awesome power. Reason I mention this, is that if my cat was clogged, it would explain the mileage and poor spool. The guy who owned the car welded some no name cat on there, on both ends, and cut off the factory exhaust flange in the process, so Its not just a matter of easily throwing on a test pipe. Anyone here ever have mileage dramatically improve after removing a bad cat?
I got the same mileage (15-16) before, with bad injectors, 4.11's, and no lean cruise.
Any more ideas would be appreciated.
