I bought a new high flow catalytic convertor that didn't need the AIR (smog) pump. I removed the pump, valves and those hard pipes. This cleaned up the engine compartment, and it will still pass emissions testing.
I also remove the EFE grid under the carb.
Just makes you you know exactly what it is and what it does before removing. Most emissions components don't hurt performance.
