My new turbo
jpwalt1987
New turbo came in from ReedPatridge@ WORK TURBO!! Borgwarner SXE T4.
69mm compressor/73mm turbine with a .88 A/R.
Very nice!
What engine and what are the build spec's that you are going to put it on?
nice looking turbo,i was wondering how the bw would do on a buick especially the response let me know.
Will you be logging shaft speed?
The S300sx3 6668 I had was adapted to a Buick 3 bolt housing with a .63 a/r. It was a beast.
Very nice!
Its going on 109 stock stroke engine. All forged internals and girdled, internally balanced with BHJ balancer and JW flywheel. Ported GN1 aluminum heads ( 249 in/ 200 ex @.550), kennebell 70mm TB and plenum, ported stock intake, Chris Hogeland is picking the cam and building the engine, PAC1203s, T and D rockers, RJC front mount, TH400 with a PTC 17 blade convertor, right now I have 80 lb/hr injectors and twin DW 300 pumps plus alky injection. I will have to build a 3.5 inch downpipe for this turbo.
Your going to have some fun!
That is going to be awesome! (y)
Thanks for the info.
Awesome Turbo! I cut the 3.5" marmon flange off my s366 and welded on a 3" vband.
What did you use to weld the V-band flange to the cast housing? I have a tig machine.
What did you use to weld the V-band flange to the cast housing? I have a big machine.
Mig welded. Just used .030 flux no gas. The housing is very easy to weld to. I've got a.91 ar housing also that I'm going to modify for 3" v band and build a qsv inside it. I've just had really good luck spooling with the nitrous that project has been put on hold.
This is how far I've made it with that project, just made the patterns.
