My TSM build thread
They're on 10 inch wheels with a 5 inch backspace. Frame is notched.
need wheels myself i like that set up.i got the frame notch and the inner well work on.
3 sets of front springs, 2 sets of shocks and 1 set of QA1 R series coilovers later, I have the ride height that makes me happy.
The rear has Wolfe adjustable perches and uses 2.5 QA1 coilover springs.
Very nice build and killer stance...
Very nice set-up...
Couple questions:
Are you running stock spindles ?
Do you know what your height is in the front ? Ground to center of wheel well.
I'm going to be doing the same set-up. I have QA1 Pro Coils, I'll be using Afco double adjustables. I have SPC uppers and lowers.
Very nice build. Clean and well detailed....
Stock spindles modified for the aerospace brakes. I'll measure it out tonite.
Adjusting ride height is not an easy task either. I bought the QA1 wrenches and they don't have much leverage.
i have the same setup up front also but i got global west arms i cant even lower my car nothing works can you let me know what length are your shocks up front.maybe they gave me the wrong set up and i hate them.how does it work for you maybe you can help me make them work.thanks
Cool. The 450s are gonna make it sit higher than stocks springs.
25 1/2 inches to the center of the wheelwell with a 26 inch tire
Very nice set-up...
Couple questions:
Thanks, that helps...
I currently have an 24-1/2" ride height with 2" drop spindles. I'm thinking I'll put the stock spindles back on with the QA1 Pro Coils(350#), I would like to get the ride height somewhere around 25".
I'm gonna crank it up to 26 inches. I've tore up way too many sets of innercooler pipes over that last 15 years.
