N/A block mods
dank GN
BlackArts Automotive (661)993-8277
what do i have to do to use a n/a 109 block for a turbo applacation??drill and tap 1/2 npt oil return what else?? i have a turbo crank. Thanks Dank gn
You don't even have to do that if you run it to the pan.
The deck height might be taller so make sure you have the right pistons.
Contact Dan at DLS, he can set you up with a slick oil pan that is built for that purpose (routing turbo oil drainback to oil pan when using N/A block).
Mike
