NC folks, pls. read
80sportcoupe
Well, what I thought was a spun rod bearing turned into a trashed crank once we tore the engine down... wondering if you guys could keep your eyes open for good local 4.1 long blocks. i definitely need the crank, and am considering just building the 4.1 instead.
Thanks,
George
Good Luck!
Did you find this from a junkyard, or advertisement or through friends/associates? Keep us posted if it works out for you!
A junkyard... car-part.com is a great resource once the yellow pages run out of junkyards to try;)
I'll post about the build in the b4black section. Mark Riley/Turbo Tune will be doing the tricky work. He's a wizard with these mills.
if you have not found a crank or a block i think i might have what you want i just bought a 86 non turbo 4.1 moter was runing i just got it so let me know what you might need i am 20 min from raliegh sping hope NC rick
