SignUp Now!Originally posted by pacecarta
instead of a mister nozzle it looks like they used 4 Fuel injectors mounted on a fuel rail in the uppipe spraying in methanol under electronic controll
its not one of razors![]()
Originally posted by Razor
http://www.highperformancepontiac.com/tech/0410pon_butler/
Can ya'll say boooostAnd no IC..
No my controller isnt on that motor. The article says a Haltech and a FAST. But the Haltech was boost and rpm referenced.. and its designed to run with fuel injectors(160's).
Tho I dont know of any fuel injector that can handle alcohol 24/7.
If I could find some huge alcohol injectors.. i'd be all over it.
Got to love the power that can be made..
The 160's are propane injectors. Problem is any alky compatible injector is typically small. All the flex fuel vehicles are econo boxes.. and those injectors are big big bucks.. when you say stainless.. it goes up up up... And the flex fuel vehicles are to run ethanol which is 85%.
Drew, I only brough the article up cuase I thought it was cute to see the trend going to alky as a fuel on a turbo charged motor. It is the future..
But as a fuel its pretty nasty stuff, and lots of maintenance. Let alone running straight alcohol.. with cylinder wash down, and other issues... its a lot of work.
Chuck, Brick.. thanks..
That Ron's flying toilet system also appears to maybe show some promise.
But all this stuff is lots of $$$.. as always![]()
