Need 3 small parts
jdpolzin
I need the two black plastic retainer rings that hold the oval conduit for the main wiring harness to the HVAC heat sheild. I also need the one clip that wraps around the silver pipe going to the AC condensor. The HVAC heat sheild screws to this clip. I put a couple pics on here to help! ----Jeremy
I might have the small metal clamp. You can have it if I do. I'll look today when I go over there. PM me your mailing addy and I'll send it when I find it. Do you need the mounting bracket for the plastic pieces too? Pretty sure I have that too.
All I have is the heat sheild. The previous owner removed it and the clips for some odd reason. If the plastic oval clips need a mounting slip then I will need those as well. Thanks for the help! Not sure if Caspers remade them or not. Hoping to find a set for the GN though. Keith, I'll PM you my address. I'll defintately take that slip if you have it! ----Jeremy
there is a bracket that the wiring harness loom bolts to. I should say the black plastic clips. You might try Kirban for the harness clips. I sure he repoped them in plastic because I bought a st from him years ago.
