silverdenali22
- Feb 8, 2009
Ok here is the problem--I pulled the motor out and rebuilt it because the number 1 cylinder was full of water. I thought that it was the head gasket or a cracked a head. I took the intake cleaned it good and checked over it, looked fine. I took the block and had it hot tanked and checked, the guy said it looked good. So I order some GN1 Heads and the bulletproof head gaskets and put it back together. I went to put the starter on and saw something coming out of the oil pan. I checked it out and it was Anti Freeze. So I looked at the number 1 cylinder and it was full of water agian!
So where is it coming from? Could the intake be cracked and I missed it or the block and the guy missed it?
