1985BuickGN
- Apr 20, 2002
Just took the car out for a spin, first after getting it together. It's an 87 Buick drivetrain, Fast system, 80lb injec., 208 cam, 72mm turbo, front mount IC, BG intake and upper plenum, forged JE pistons, stock crank, stock rods, GN1 heads untouched and a Bruce built trans. Had this set-up running in a hybrid car and had a bigger cam in it (218), now it's where it should be (in a Buick) and I'm trying to tune it (guy that I had helping before is'nt around now and I'm on my own). Got it to idle well and tip-in response was pretty good, so I went for a drive and under light acceleration it surges, not bad but enough to notice it also does it at cruising speed, the rpm's jump up and down a few hundred. Not sure what I need to adjust for this. Did a WOT blast for a few seconds to get some numbers logged and the O2 correction is at 24.2% as soon as I let off it goes down to -25%. Should I adjust the VE numbers up for +O2 correction and down for -O2 correction? Boost is at 12psi (playing it safe for now) and A/F ratio at idle is at 13.0. If anyone knows of other things I should check/set I would really appreciate the help. Thank you. Paul.
