Reply
I just got a bad booster problem, Kirban I'm sure will make it right. He's just the middle man & I have no problem with him nor have I ever.
Actually I had to do just that ,machined the that rod down about 1/16th to even get the front brakes to release. Check valve was also fine.needle point, bingo, shuffleboard. yea. sure!
check the rod between the master and booster, MUST be some clearance,
or brake will not release, you have a known good check valve ??
let me know if I can help
thanks
