My 87 T is leaking like a siv, Its time to replace the oil pan gasket, rear main seal, and valve cover gaskets. What is the best brand or type to use? What does everyone recommend? Are cork the best or something else? and do you guys put anything on your gaskets(especially the cork type) during assembly to help them seal? I only want to do this job once so any advice would be greatly appreciated. Also I am going to replace the motor and tranny mounts while I am at it (135,000 miles on original mounts), are stock mounts ok or should I spring for something better? It is basically a stock motor with the usual fuel system upgrades, big mouth cold air kit, 3 inch downpipe and exhaust. stock turbo still(probably changed at some point) and many other small upgrades, nothing too exotic. My goals are good reliability and able to run low 12's. So what mounts do you all recommend? Are stock mounts good or do I need to spring for the poly mounts?
Thanks for the advice. Jeff
