For the first time in 19 years I regret having T-Tops
You know that spot, in the front , between the black plate and the seal? Well I saw a "little" rust a while back and finally got around to removing the plate. Turns out the rust ran all the way across the front, just on the one side! My car has not been in the rain since 1991 in BG!! It's still riding on the original brakes and I was freaked to see so much rust.
I do wash it so that must was the source of the water. In the process of removing the plate, I tore the damn double sided seal that goes between the plate and the body.
Anyone know where I can get this stuff? It's about and inch wide and 1/4 inch think.
Fortunately, I have set of new trim "plates" and the complete T-Top window rubber ($400 from GM
). It looks like a difficult job to replace this rubber as it is a long piece that starts at the door, goes along the T-Top and back down the door
Can anyone who has had the same proplem offer any advice as to how to repair the rusted area, find that double sided seal and the best way to remove and replace the rubber? THANKS
