According to my GM literature, the 4 digit code would break down as:
1st digit
B- 250 and 350 transmission
C- 200/2004R/Pre '85 700R4 with 27 spline input
D- '85 and later 700R4 with 30 spline input
2nd digit
"K" factor-engineering term that means the speed of one member divided by the square root of the torque on the same member. This is calculated at stall conditions.. On a 298mm torque converter, you can multiply the "K" factor by 14.2574 to get the stall speed.
A= 142=2024 stall
B= 140=1996 stall
C= 135=1925 stall
D= 130=1853 stall
E= 115=1639 stall
F= 110=1568 stall
G= 100=1425 stall
H= 97=1383 stall
J= 89=1269 stall
K= 85=1211 stall
3rd digit
0 = No clutch
1 = 300ft/lb 43 degrees of travel
2 = 240ft/lb 46 degrees of travel
3 = 290ft/lb 44 degrees of travel
4 = 160ft/lb 37 degrees of travel
5 = 220ft/lb 35 degrees of travel
6 = 195ft/lb 42 degrees of travel
7 = 195ft/lb 30 degrees of travel
8 = 300ft/lb 44 degrees of travel
9 = 290ft/lb 44 degrees of travel
A = 300ft/lb 29 degrees of travel
B = 300ft/lb 44 degrees of travel
C = 330ft/lb 28 degrees of travel
4th digit
cover style and number of mounting lugs and method of welding
A = open cover (no clutch), 3 lugs with one weld per lug (gas)
B = open cover (no clutch) 3 lugs with three welds per lug (diesel)
C = converter clutch type, 3 lugs with one weld per lug (gas)
D = converter clutch type, 3 lugs with 180 degree weld on each lug (diesel)
E = converter clutch type, 6 lugs with 180 degree weld on each lug (diesel)
F = converter clutch type, 3 lugs 245mm style lug
Hope this helps.
