NEED driveshaft. asap.
rwrows
i just put a gn rear in my regal and i need a driveshaft that will work with the TH350 and the 8.5 rear. i was told a stock gn driveshaft will work perfectly. anyone??? i'm located in philly so i'm trying to pick one up asap. thanks.
yes the stock one should fit just fine. I changed over a 79 trans am from 350 to 200r4 and it still worked fine. Your just going the other way. Daniel Ray
you must use the gn drive shaft not the factory one for the 7.5 ringgear
