Trouble shooting - NOT WORKING FAN. I checked each wire for differences in voltage while in different settings. To see if i could get the control module to turn ON the fan but NO luck. Side note - The dash controller works on every other function besides turning on the fan.
volts @ fan control module 5 pin plug
Also verified ground at control module and power.
Fan control module is brand new from Caspers (yes that $250.00 part) i even sent it back to have them double check it and they said its good. But that damn thing does NOT send out any power to the fan.
Fan is working- i ran a manual ON/OFF switch into the cabin to be able to use the heat.
What do you see wrong?
Settings
85*--- Defog ---- High -- Battery volts 12.50 car off.
Purple wire =1.04 V, Green wire= 11.80v
Red wire not used, Green/black wire=10.94,
Brown/White=12.26,
Fan Purple wire=3.4 disconnected from fan. Connected to the fan=0.0
Settings
85*---Heat---High Bat 12.46 Car off
P/ wire=12.33 V, Green wire--O.O V
R/wire=not used, G/B =11.39, B/W 12.21
Fan purple wire =5.13 disconnected from the fan- 0 when connected to the fan.
Settings
65---Bi/Level---Bat 12.42v car off
P/wire=1.03, G/wire 11.69
R/wire=not used, G/B wire=5.13, B/W12.19
Fan purple wire =5.18 disconnected from the fan- 0 when connected.
