need help car poping and will not run
Had the same thing happen to me last year, there is a little pin that holds the top of the cam sensor together, the pin on mine broke and the cap rotated. Remove the plastic cover and you will see the cap and pin.
Is your fuel gauge accurate? It sounds to me like it's out of gas [emoji618]️
That bone was thrown 2 weeks ago and no results have been posted. Just guesses and wasted money
Umm...yep you are right, I missed your post of the exact same thing. :inpain:
That will teach me to read the thread from the beginning. :banghead:
well guys i found my problem i went back to the cam sensor pulled the cap off cap tabs were good so i look at the
steel wheel the tab that holds it in place was gone i removed the screw turned the wheel back to where the tab broke put
the cap back on and it fired right up and ran fine no backfire. so i will be buying a new cam sensor all most 300$$ wow
thanks for all the help guys
Scott, at GNS preformance. He is vender here on the site. Look up his site and you will see the cam sensors.
thanks for the link will be ordering a kit frist thind in the morning to fix it only 22dollars way better than almost 300 once again thanks guys
