Need Help finding a boost gauge
bishir
Serenity Now
I would like to find either a black faced or digital boost gauge that reads vacuum and up to 30#s of boost. Digital with memory would be the best, but let me know if you know of one. :p
Thanks,
James
That works! Not a big fan of the yellow, but I do like the green light option.
Any digital boost gauges in this range? Easier to see a number than read a gauge when going WOT.
James
Go to westach.com
Very cool guages ,and all black with green light at night.
HTH:)
I have an autometer sport compact in mine, i like it a lot, but mine is only a +20 boost, so it goes off the scale sometimes ;)
i'll get a pict for you if you want.
Autometer Electric Boost/Vac w/warning and boost recall
J,
Autometer has a new electric 30/30 Boost/Vac gauge with max boost warning and max boost recall. It's expensive, uses a 3 bar MAP sensor (included) and is the cat's meow!! I have the 2 5/8" unit and its easy to see and work with. Let me know what size you're looking for and maybe I can help.
Tom Houser
Performance Instruments
www.gnxdash.com
J,
I'm sure it's less expensive than wrecking my car trying to read a boost gauge at WOT. :p I want it for an A Pillar gauge pod so whatever size those are normally.
Thanks,
James
Autometer
If you want a better looking (IMO) autometer for a GN, go with the z-series. Black face, white lettering, black bezel. P/N 2614 is 30-30 what you want.
