Need help identifying GNX rims??
radtech
How do I know if I have real GNX rims? I need a center cap for 1 rim and it would need to be a cap that inserts to the "inside " of the rim surface. I have 4 new caps, but they are different and attach on the outside if the hole and hold on to the lugs. Thanks!!
What is the back spacing on the rims you have!!!! GTA front's are 4.5" back spacing. GTA rear's have a bigger back spacing, (only used on GN's with spacers).
I believe the original GNX rim's had a 4" back spacing, but not positive.
Hope this helps
Markings
In addition to front only, GNX wheels are marked off -15 (see pix). Rears are marked rear only and off -23.
