griffgoody
- Mar 19, 2012
Been working on my T-type that has been stored for 8 yrs. Worked out alot of bugs. Running good. But the back of the motor is wet with oil. Not coming from intake gasket (been replaed). Valve cover gaskets are good. It seems like it is coming from the backside of the headers (stock headers). When you drive the car. Or on start up. The car has smoke coming out both pipes. Not a whole lot. Do you think this is coming from the turbo. If so, what is needed. Or what should I check or do. John
