need help on picking best turbo
figga8n
not sure what size turbo to pick. all stock block with bolt on upgrades check sig. im looking to get the best turbo i can need advice please
:cool: What are your ET goals? Have you been to the track yet?
DOUNVME nice picture!!
I wouldn't go bigger then a GT6152E which will also go nice with your injectors...Gonna need at least a 3200 stall...I have a 3000 stall on my 6152 and it works fine at the track, but it's a bit laggy on the street.
If you don't want to go with a loose stall like that then a 6131 will work with a tighter stall.
Under Pressure said:
I Had A Te-44 With 57lbs Inj, 3500 # Car Ran 11.55 Et So I Dont See A Problem Either.
Hey Adam,
what kidn of duty cycle were you running with those 57's. I have 50's right now and was told that they might be a little small for the ET range you mentioned.
Glen
DCVING 6 said:
Hey Adam,
Glen
i believe its at 80% what et you looking for?
A local hero Ed has made 529RWHP with a stock motor and a PT64E.
I have been thinking about the GT3561.
I want to max out the stock turbo on alcky first! :eek:
Me too...... Ed Brewer can run 11.37 on a stock longblock/stock turbo in a full weight car......
There are plenty of people with alot more parts that would be very happy with a 11.37 slip.
My personal goal is 11.50-11.60 with the stocker before I go bigger..... it should only get quicker.....
I don't have the nuts for that on my daily driver.
11.99 would be the magic number for me.
If not Julio will give me my money back. ;)
