Ok...removing the harmonic balancer seems like a pretty basic procedure but I have been unsuccessful so far and I'm out of ideas.
The car is my '87 GN, stock block, stock crank, etc. I've removed the IC and crank pully so the balancer bolt is right there in plain sight. I've attempted to loosen the balancer bolt with an 18" long, 1/2" drive breaker bar and 1 1/8" socket turning counter-clockwise (righty-tighty, lefty loosy). First problem was crank turning (I expected that) - so I braced the crank by sticking a #3 Craftsman screw-driver between the torque converter and the flexplate and rotating the crank until the screw-driver was wedged up againsted the transmission bellhousing. Then I went back up to the front of the engine and tried to back off the balancer bolt only to snap the screw driver... (picture below)
and that's not a small screw-driver, the shaft is about 1/8" larger in diameter than a pencil. I have larger screwdrivers, but I grabbed this one first.
So now what? How do I keep the crank from turning??
Anyone know what the torque spec. for the balancer bolt is? This one seems like it's over torqued to me.
Any help is appreciated.
