Here are the codes I'm showing on T-Link
34 - MAF/MAS Sensor low (Because of the Trans+ and 3" LT1 MAF, so disregard)
35 - IAC and/or idle speed error
41 - Cam Sensor Failure
45 - Exhaust rich condition
51 - Incorrect PROM checksum
52 - Bad or Missing Calpack
54 - Fuel Pump Voltage low
Physically checked the volts on the fuel pump and they're 13.XX so it's probably just not recognizing the fuel pump is there because of how it's hotwired.
We just cleaned the IAC, and it still shows 0 so it must be junk
The O2 sensor is going to be replaced tomorrow
I have an extender chip with the Trans+ so does that have anything to do with the Calpack code?
What codes are typical with the Trans+ besides the MAF low?
The code that really scares me is the Cam Sensor failure..... what do you all think?
