NEED HELP, Throwing codes
DR. EVIL
THE DARKSIDE
Here are the codes I'm showing on T-Link
34 - MAF/MAS Sensor low (Because of the Trans+ and 3" LT1 MAF, so disregard)
35 - IAC and/or idle speed error
41 - Cam Sensor Failure
45 - Exhaust rich condition
51 - Incorrect PROM checksum
52 - Bad or Missing Calpack
54 - Fuel Pump Voltage low
Physically checked the volts on the fuel pump and they're 13.XX so it's probably just not recognizing the fuel pump is there because of how it's hotwired.
We just cleaned the IAC, and it still shows 0 so it must be junk
The O2 sensor is going to be replaced tomorrow
I have an extender chip with the Trans+ so does that have anything to do with the Calpack code?
What codes are typical with the Trans+ besides the MAF low?
The code that really scares me is the Cam Sensor failure..... what do you all think?
Sounds like you may have gotten the "fast update" code for Scanmaster in your Extender chip. That fast update patch does really wierd things to ALDL based scan tools!!
It's usually either that or an electrical glitch somewhere. Throwing that many codes all at once is the give-away. Things don't fail that bad/fast.
I agree with Dave ... sounds like the fast update patch might be in the chip.
V3.0 will read the fast update patch in the next downloadable update. We're testing the various "flavors" right now. The problem we are struggling with is displaying the REPLAY of the data stream, but I think we have a handle on it.
Hmmm, that's starting to sound more reasonable :)
I'm still sure my O2 and IAC are bad though :( Oh well, they aren't all that difficult to deal with.
I was starting to wonder after seeing a Water Injection Failure code a couple times:eek:
