t-topflyer
- Aug 8, 2007
Working on a turbo buick in which the 1-2 shift is fine. The 2-3 shift if it's in D and especially the 3-4 shift in O/D seems to happen too soon sometimes and lug and stay in the high gear when it shouldn't. Doesn't slip or have any other issues that I can tell. Replaced the tcc solenoid and adjusted the TV cable but it acts the same.
Transmission has some mods such as a 10 vane rotor, hardened steel vane rings, 500 boost valve, billet super servo, kevlar band, hp clutches, modified seperator plate, modified accumulators, hardened sun gear shell, heavy duty pressure regulator valve and spring, double pump slide springs, rebuilt hp torque convertor 2800 stall
Car is othewise completely stock chip and all. Any ideas?
