- May 28, 2001
Here's a start......
Voltage Drop Testing
The purpose of the testing is to determine at what point the system is losing voltage.
IE: From 1 side of the batt cut off sw, to the other.
Across the + and - sides of the starter.
ETC, ETC.
There are many more articles on the subject w/ a Google search.
Keep in mind, that a volt drop HAS to be done w/ the system under load. If it's not, it's just a continuity test.
Chuck, could you explain how to do a volt drop test and what will it show me?
Checked voltage with different meter. I was 14.09 at alternator and 13.98 at battery. Even with bad tester the numbers should be consistent at least at the plug in by gas tank. Why so low through scan master?
ETC, ETC.
