Need help to identify this cam......
Sixstringterror
It has on the end (towards the back of the engine) in the center of the cam some grinding numbers....It says ....BV6 5440/5440 or 5990/5990...Cant tell if its the first or second one..It also says H9+2....At the bottom it says P8210 and in the center it says CC....Please help me out with this guys.....Is it stock or compitition cam or what.......TIA................Tim...I could load up some pictures but they have to be so small to get them on here....I dont understand how everybody else downloads all these big pictures onto the site...anyway.....Tim
Should be a Comp 206/206 that was custom ground. You will need to verify that with a degree wheel but I am 99% sure
Mike
Is this a pretty good cam? What would be the specs on it.Is this a hydraulic cam or flat tappet?.What size springs could I use...Would a set of postons stock 100 lbs valve springs be alright with it? Would this be a good cam to upgrade to from stock?.....Thanks a lot for the help mike. If you could answer a few more of these Id be grateful...By the way, How would you degree the cam like you said.....Tim
