need help- will Champion 3.8 steel heads fit 4.1
5 LTR KLR
So I was wonder.... I have a 4.1 block and a set of Champion steel ported 3.8 heads and was wondering will they work on a 4.1 block???
:confused:
So there will be no problem with the water jackets???..do to someone posted this in another posted ad:
"Make sure your water ports that are along the lifter valley are correct and everything else should swap over. We did a 4.1 into a Vega wagon and the heads were wrong for the block and it filled the block completely with water when we were ready to fire it up. Your 85 should have a 20 bolt oil pan and the 4.1 will have a 14 bolt. The timing cover and pan will be different in those respects and the 4.1 oil pan won't have an oil baffle in it"
Or anything else I need to do to make these heads fit good???? I want to use Cometic head gaskets and will be using 0.30
