need help with a almuminum radiator
  • Thread starter Thread starter Raist103
  • Start date Start date
R
Raist103
Guest
It is for my stang 67, it has a 351 W that is running very hot. (pushing some good HP) My ? is I can not find anyone who makes one in a 4 core to fit. I have tried summit, (2 core for $560) and jegs9just 1 core). Does anyone know a place that custom makes one cheap or know where I can find on that fits? I know cheap and custom should not be used in the same sentance but I am on a budget.
raistlin103@hotmail.com
I know a local shop here in Chicago sell the 2 core aluminum radiator for $189.00 or some thing like that. Dr. boost on this board has the info. I will have him post the ph# or address. It doesn't have trans or oil cooler but it is good size for our GNs. Iam pretty sure they should be able to get something for your Stang.
Good luck
Prasad
the 2 core aluminum radiator is actually betterthan the 4 core brass because the tubes are an inch to an inch and a half wide instead of the half inch wide brass. i got one from VSN products in merriville indiana. it has no coolers in it . measure your present radiator and note the inlet and outlet positions.
i went through a dealer of theirs called Whites Pits Stop in Lansing Illinois. their number is 708- 418-8400.
the price was 189.
surej
might want to call jegs or summit back up and ask about their griffin universal fit ones, they have 2 different tube sizes (the larger costs a bit more) , and different sizes for ford or chevy (difference is where the inlet/outlets are). That is how I got my Gn one and it was like $180 or something. they also have lots of sizes so finding one that works shouldn't be a problem. you will have to so some work on the mounting and such but it saves a lot of money for other stuff and it is a AL radiator.
I also would stop looking for a 4 core brass unit it will not cool as well as a 2 core AL
