John Larkin
Sublime Master of Turbology
- May 25, 2001
Replaced the TCC solenoid since it locked up on my Friday night. Hope it's not in the ECM itself. I touched the old TCC to the battery terminals to see if it would energize and it sparked.
Reinstalled everything and all checked out to spec. Now a code 31 sets after I am in 4th gear and is popping the ECM/SOL fuse. I had to replace the 4th gear pressure switch too since I broke the tip off it.
Also the Cig/Clk fuse is popping the minute I replace it. I guess the only way to figure this out is 2 things:
1. Check every accessory for continuity from the Cig/Clk fuse and see if there are any wires shorting to ground.
2. Check continuity from the brake switch through the trans plug and see whats up there.
I'm really at a loss since the gnttype diagrams are darn hard to read. Any help appreciated. I did a search on code 31 and found claims of pinched wires, etc.
Guess I'll start with the Cig/Clk fuse since it should be unrelated.
