The car has been running fine till a couple days ago. After I would start off when the car had been shut off for a while, maybe 30 mins to an hour, after driving and getting up to normal temp the SES light would come on. I checked and it had a code 13 O2 sensor. I cleared the code and it hasn't come back yet. Today I took it to fill up with gas. Left it running while filling up, then started off and drove a little ways and it started cutting out then it would come back. The SES light came on again and it started running rough and eventually died. I checked the codes again and it was a 42. I tried to start it back and it would start then die. I cleared the codes again and it cranked and I was able to make it home. Any ideas on what might be going on? It's basically stock but has the basic bolt ons LS1 Maf and translator, 60 lb injectors, Alkycontrol kit, TA49, Precision intercooler, extender chip, ATR stainless exhaust, larger downpipe, heated O2 sensor and probably some other things I've probably forgotten. Recently I've replaced a heater core, fixed the A/C, and had some brake and powermaster problems and I replaced the pump motor and accumulator, proportioning valve and rear brake hardware and pads.
