Need help with fitting size on master cylinder
John Larkin
Sublime Master of Turbology
I need to know what thread the master cylinder fittings are, particularly the front one. And two bonus questions: is there an adapter to go from the master cylinder to normal parts store brake line inverted flare thread using 1/4" line? Also I need a fitting that goes from the stock brake line to 1/4" NPT. These are toughies for sure! Thanks if you can help.
can't help you with exact thread sizes, but here's a link to the Weatherhead fitting catalog master index that will almost certainly have what you want : http://www2.dana.com/expert/wc.dll?cvsp~depdf~3~_0O00LV0DQ~
There are several sections pertaining to "Inverted Flare" and "brake line" fittings & adapters.
The mass market retail chains don't usually carry Weatherhead brand, but many NAPA stores have it behind the counter ...
