Ok first ill start with the what the car has.
1987 grand national
3.8 109 block
Big mouth cold air intake
LS1 3 1\2 inch mass air with translator
3 1\2 inch intake pipe
gt-61 turbo from limit
.63 exh. housing with hd actuator
stock intercooler with step up neck
flared 62-65mm throttle body
rjc power plate
stock intake ( for now )
stock heads ( for now )
stock block ( for now )
stock cam ( for now )
stock headers
3.5 inch terry houston down pipe with dump
dual dynomax ss ultraflows muffler system
walbro 340m pump hot wired
50lb msd injectors
adjustable fuel pressure regulator
chip by turbotweak
volt booster
scan master II
Has boost gauge fuel pressure gauge and all of that normal stuff.
soft rear shoes bigger brake cylinders etc..
trans pro built with parts by performance trans
3000 stall full race lockup convertor
stock rear 3.42 with boxed upper and lowers
all braces front and rear.
poly bushings all through and all missing bushings put in.
Will be puting alky on also. Most likey razors kit
Ok so theres what I have. now for the questions??
What should I do to the long block ( it has to be rebuilt )
Pistons? JE's? Speed pro? Etc
heads? Stock ported? Champion? Roller rockers? Etc
Head gaskets? Whats the best?
Intake? Stock? Ported? Aftermarket?
Cam? whatever would work best with a gt-61 and a 3000 stall I guess??
Any parts im missing any where on the car please advise??
Looking to spend in the $1500 to $3000 range
This is a street car so driveablity is a factor. Looking to go fast with class!!
I don't want any new ZO6 making me sweat!! :tongue:
I would like to get into the 10's if possible
Any input will help
Thanks shawn
1987 grand national
3.8 109 block
rjc power plate
stock headers
50lb msd injectors
chip by turbotweak
volt booster
scan master II
Any input will help
Thanks shawn
