Dave,
I called Rick saturday and we went thru my settings. He pointed out that the spark base should be 15, so I changed it. I thought the spark base was based on the fuel in the car. 93 octane=16.4. Another thing that we found was the DC was at +30.5. I thought it was duty cycle for the injectors initially but it is the speed density compensation. I replaced the IAT hoping it would fix the temp problem. It is still reading -39??? Problem must be in the extension or in my wiring harness. I will track that down when I get it back.
Key on, engine off the MAF signal was 1.1, Rick pointed out that it should be higher as well. Didn't note what it was before I dropped the car off. Thanks for all of the help guys!
Without proper sensor signals, the Pro cannot possibly calculate correct airflow. You need to spend some time with a voltmeter and figure out whats goofed up.
Bob
