I am using a scan master. I had the alky tuned in pretty good with the street chip while awaiting my alky chip, now it is back to square 1.   The alky chip was supposed to produce more boost however it didn't. I increased the boost via waste gate rod to around 21 # .  The car seems to quit pulling around 4200 rpm and holds in 2nd gear too long before shifting. I have added and subtracted fuel and timing in the chip but it only seems to change knock retard and not the flat power curve. It is also lazier off the line than with the street chip before the alky. My O2 numbers range from 750 to 800 depending on the settings. Any suggestions would be greatly appreciated.
