redhotrod
Turbo Happy
- Nov 19, 2002
Hey there
I'm trying to get my car tuned in for the new race season starting this coming weekend and I'm having trouble with knock relating to O2's I believe.
Heres the setup I'm working with--
84 hotair motor, ported tb(60mm), ported intake, ta49 with .82 exhaust housing, 2.5" dp, k&n filter, 42.5lb injectors, comp 212 cam, new valve springs and timing chain, walbro 340, adj fp regulater, adj wastegate rod, twin electric fans, and 86 ecm with chip burned for above mods. I do have a diy alky kit on order at the moment but don't want to just band aid my problem with knock.
Just to try and get rid of my knock, I have the static fp at 43lbs, which is running a bit rich at idle(850mv) but when I get into the gas above 11 psi boost, knock comes in and O2's are down below 750mv. Right now I have my wastegate rod as tight as i can get it and if I really stand on it, knock comes on quick.
Is there a way for me to fix this with a chip? Or is the alchohol the only fix? I can email turbolink files if anyone needs to see. Oh yeah, and I do run nothing but sunoco ultra 94 with their added methanol.
