Hi... I need help fixing my horn. When the horn button is removed, just tapping the steering wheel will set the horn off. It also happens randomly when I go around corners. Has anyone else had this problem?
Thanks,
Kristina
sounds like the power wire may be chafed and rubbing on metal, or the horn button can also be the problem. otherwise, your going to need a wiring diagram to check for short to positive or short to ground
I had same problem with my 84. the foam between the metal plates was wore out and allowed the plates to touch. just add something to replace the foam and it should help.
