What i have is a 87 gn with no power to the fuel pump relay i can jump it with power and the car runs i have all good grounds this the deal pulled the car in pulled the motor built a new fresh put it back in the car and no fuel pump so i checked all my wiring and connections and everything is were i removed it from checked all fuses had a new relay in the tool box no such luck any idea does this relay get power from the ecm? however i did check power from the battery to the ecm its has power
thanks for any help that i can get
