This winter I will be building the engine in my T for some very low 10 second and hopefully high 9 second power. I pretty much have the combination set except the cam. I am torn between going with a good flat tappet like like Jason Cramer did for his TSM combination (9.9x e.t.) and a roller. The reason why I am torn is this car is going to be a street/strip car, not a dedicated drag car. I'm really not thrilled at the idea of setting lash with a hydraulic roller every so often. If need be, I will go with a roller, though.
The combination is going to be a girdled 109 with GN1s and a Turbonetics P trim T72. The rest of the combo is already on the engine; 70mm t-body, ported intake, FMIC, 72lb. injectors and supporting fuel system, etc. Basically, I need a cam that will compliment the GN1s and the T72. I am currently running the stock ECM with an Eric Marshall chip, but may go to a Gen. 7 DFI. I could very well call my tuner (Job Spetter Jr.) and get his recommendation, but I already know what he'll say, "Gen. 7 and a solid roller". I was also thinking I could go with the same cam as my bro-in-law as I know which springs, locks and pushrods work with this cam and GN1s (that is if I decide to go with a hydraulic roller). His cam's specs are...
RPM range...1500-6200
Duration @ .050...218/212
Lift...511/.504
Spe. angle...112*
So, some input from you guys out there in TSM land would be great. The sooner the better as I need to get my engine out to the machine shop.
Thanks.
Lift...511/.504
Spe. angle...112*
Thanks.
