Some moron is saying that in any turbo car you can build boost in neutral and that load has nothing to do with boost.
What sparked this whole thing is that some RX7 guy said he can build 5#'s of boost in first gear with the cluth pedal pressed in all the way...I said maybe rotory engines are different because my more doesn't build boost in neutral and some tool comes in and responds with this
So am I right, that load is required to build boost or is he right?
if you knew how a piston engine works, and how a turbo works, you would realise that anytime the engine is running, it is expelling gas, thus spinning the turbine on the turbo, thus creating boost. (well maybe not at idle or low rpms, but the turbo is still spinning, just not fast enough to produce boost.)
An engine is basically an air pump, whatever gas goes in, goes right back out. It doesnt matter if there is load on the engine or not, the air is still going to be pumping.
If an engine in gear is running at 4500 rpm and moving 280 cfm out, it will move the same ammount of air no matter if its in gear or not. This air will spin the turbo, thus creating boost. The turbo has no clue whether the car is under load.
A turbo WILL make boost in neutral, it doesnt matter if its a rotary or piston, they are both air pumps, they will both be pumping air if they are running, no matter if they are under load or not.
My best freind has a Turbo TBird, he spins up his turbo all the time at lights.
