OK my car started to break up from a start and would keep breaking up as you drive. It also would do it if u revved it in park for a couple of sec. So I get started and I swap out the ignition module/coil NOTHIN. Then I switch the MAF sensor with a known good one (OFF of my bro's GN) got a little better but after driving for like 10 minutes the problem came right back. Changed the O2 sensor, computer, chip, IAC, Reset IAC and TPS. Go back out and test drive it and it runs great for 3/4 around the block, then bam the problem is back. Exactly as when I started. What else could it be????
