BARRACUDA1968
- May 4, 2011
I made a couple pulls yesterday using the powerlogger. The first run was a 3rd gear pull and the second was a roll on from 15 mph through the gears. I got cut off at 87 mph on this run for some reason.
Would like some insight. I had some weird knock, probably from being too rich but take a look. I just re torqued my knock sensor to 14 ft pounds and now when I get knock it's crazy high.
My chip is a TT 93 with alky timing is 23/21 I had 1 degree of timing out in 1st and 3 degrees in the other gears. Fuel is chip setting. Alky on 6.
Boost is 22
Boost is 22
