K
KECHME
Guest
I recently installed my FAST managment system, and I have a had a few problems with it. I won't go into the details because they would bore you to death. My last (hopefully ) problem is that for some reason I have no wide band function at all. When you pull up the dash , the actual AF reads 0 as does the wide band O2. I have been dealing with Dave from wheel to wheel and he has been very helpfull, but I need to get this car tunned before the weekend and things are not going very quickly over the phone. Here are a few more particulars about what is going on. I have traced the wires back to the PCM and checked continuity of all of them and everything checks out. I have also checked to make sure that there is voltage present on the ign lead right at the sensor it self. The calibration # on the sensor matches the serial # on the back of the PCM. One last thing, I left the O2 sensor powered up for around 4 hours on accident and I am affraid that I could have damaged it . I ran the car today for about 10 minutes and the sensor does'nt seem to be getting hot, if you look into the front of the sensor it does'nt glow orange like the coil is still functioning. I was told that there is an excite program that I may be able to get via Email, if any one has this program I would be gratefull if you could help me out by sending it to me at == sean@freeseautosport.com . The UEGO(V) starts at 3.53 volts and stays there all the time, The UEGOS(V) starts at 1.02 and stays there all the time . I was told these figures are the way to properly diagnose a problem with the wide band. Sorry for the long boring post, but any info would be greatly appreciated.
