need some help with the brakes
  • Thread starter Thread starter hondaman-iac
  • Start date Start date
H
hondaman-iac
Guest
hey guys
sorry for the intrusion but i need some help with my mom's 92 buick le sabre custom. here is my problem: when stepping on the brakes the car seems to jerk a lot. i think it is one of the abs sensores that is going out and i was wondering if there is like a way to check which of the sensores is messed up. the car has new brake pads, new front rotors, and the only thing that i'm assuming is wrong is one of the abs sensors. How can i find out which one is at fault ? I guess there should be like a service connector, and when shortened will throw off the codes into the dash. Also can you tell me where to find a list of codes for the car ? I'm assuming the car is a ODBI.
thanks
This is turbobuick.com, not 3.8L Buick LeSabre.com. Our cars don't even have ABS. Try Click and Clack.
Post this question in the lounge and you won't get ragged..
Does it always pull to one side? Have you checked the calipers as one may be sticking.. Pull the pin out of the caliper and make sure it is smooth and not pitting or gunked up..
That's a start..
That's a start..
i posted it in the lounge. and no it does not pull to one side, it just jerks a lot
