THe TPS connector was broke on my TTA, Instead on spliceing in the new connector I took the pins out of the old one and took the connector body off and install the new connector body in it's place. My question is I want to make sure I put the wires back in the correct place on the sensor, On the top of the sensor (slot A) I have a light gray wire, In the Middle (slot B) is a blue wire, on the bottom (slot C) is a black wire. Did I put them in the correct order? I just want to make sure there pluged in the correct order. Thanks, Jason
