Black Sunshine
Slacker
- Aug 7, 2007
Hi, I've been having problems with detonation for years. Last year a vacuum leak was found that helped quite a bit but didn't go away completely. Now I got that RJC Boost controller and the knock goes through the roof. Can barely put the pedal halfway down until the knock reads about 6 degrees on my scanmaster. If I floor it it shoots to around 15-22 degrees!
Other than the setup in my sig everything else is stock. I run Mobil premium gas. Thanks in advance. My trans is going bad and starting to slip don't want to fry the engine too. :frown:
